Routing Pigtail
Old Jan 11, 2026 | 07:53 PM
Dylsol's Avatar
Post Routing Pigtail
I am having trouble routing this connector under the distributor on my 93 Del Sol si with a d16z6. Any know where to route this?
Old Jan 11, 2026 | 08:22 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Routing Pigtail
It suppose to route to the O2 sensor on the stock exhaust manifold.
Old Jan 11, 2026 | 09:08 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Your photo shows a ceramic coated aftermarket header bolted to your engine... it is likely that the O2 sensor is now connected to the header at the back near the collector (and not at the front as tech8 has pictured), which is under the intake manifold near the rear cross member. You would either have to open up the engine harness exposing all of the wiring and route the plug you have pictured back under the intake manifold along the main engine harness bundle so that your original O2 sensor wiring can plug into it... then re-loom and tape it all back up, or purchase/make an O2 wiring extension that connects your two current plugs. If you want to buy one, PM me for a source... they have a few different lengths available and in stock.
badpaw
Aug 26, 2018 08:59 AM
itsmejto
Oct 25, 2008 04:04 PM
pyro_freak8
Jan 3, 2004 08:54 PM
Black93DelSolSi
Jul 31, 2003 04:22 PM
AdamQ3B85
24
Jul 4, 2003 05:29 AM
