2000 civic blower motor stuck on high any time key is on
Old Dec 2, 2025 | 04:25 PM
garciabro's Avatar
Default 2000 civic blower motor stuck on high any time key is on
the problem was the blower fan high relay located low behind the glovebox hope this helps, this issue occurred after disconnecting battery while car was running
Old Dec 3, 2025 | 01:26 PM
sivicman's Avatar
Default Re: 2000 civic blower motor stuck on high any time key is on
Is there a reason why you disconnected the battery while it was running? If you have no blower speeds, than more than likely the resister is bad.
Old Dec 3, 2025 | 01:30 PM
garciabro's Avatar
I disconnected the battery while running because the alternator was overcharging and I had to make it home without killing the battery. I have already fixed this issue. It was the blower fan high relay.
David Berger
Honda Civic (2001 - 2005)
Aug 4, 2017 11:59 AM
JDMFairlady280Z
May 22, 2010 10:50 AM
punk_0333
Jan 8, 2010 09:08 PM
bjacobia
Aug 31, 2008 08:59 PM
