Honda CR-V & Element 2WD & 4WD Element & CR-V
Manually Locking Drivers Door (Switch above handle), Auto Locks All doors?
Old Nov 29, 2025 | 12:02 PM
EastCorridor's Avatar
Default Manually Locking Drivers Door (Switch above handle), Auto Locks All doors?
I'm aware of customizing the auto lock feature by putting it in park and turning the key to the II sign and all that so when you drive above Xmph it doesn't auto lock.
But this is when the car is parked and turned off and you're just manually locking the little red switch on the driver's door with your fingers.
If you lock it manually with your fingers (above the chrome pull handle), it auto locks all four doors, it triggers all the doors to lock and It wears down mechanisms, even if not, I would like to turn that off especially when the doors are already locked. Can that be turned off? or no?
2007 Honda CRV
Thanks
mistersink
Aug 22, 2022 05:43 AM
reemas
Honda Civic (2006 - 2015)
16
Jan 20, 2009 05:35 PM
