Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Torque Motor Mount Bracket/Spacer
Old Nov 25, 2025 | 04:28 PM
Reverendjim's Avatar
Default Torque Motor Mount Bracket/Spacer
This is on a 2007 Civic LX. I am wondering about the purpose of this bracket. Is it really necessary and what purpose does it serve. All replies are appreciated.
Regards
- Rev
Old Nov 26, 2025 | 09:35 PM
Default Re: Torque Motor Mount Bracket/Spacer
I see that there are several views and no replies. Maybe there is confusion about what I called the torque thing. The factory service manuel refers to it as the torque rod. I hope that makes things a bit more clear and I can get some valid responses.
Thank you in advance.
- rev -
Old Nov 27, 2025 | 03:14 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Honda put it there for a reason... it is likely because there is only ONE mount supporting and controlling engine movement on that side... that bracket will help with the latter. It could also be to reduce NVH. Your pic doesn't show how it is attached nor it's entire shape... better pics may be helpful. WHY do you want to remove it ?
Old Nov 27, 2025 | 07:31 PM
Thank you for your reply. I understand that Honda put it there for a reason. Now, I don't want to sound like an A-hole but apparently with all your fleet, you have no experience with 2006-11 1.8L motors. I am attaching an edited excerpt from the Service Manual and a rendition of the bracket itself for your information. As you will see, the torque rod has three attachment points. One at the fire wall and two at the top of the passenger side mount bracket that also attaches at the front fender area location. So, there is more than one point of the torque rod to be attached. Now, if you look closely at the originally posted image, you can see the bracket/spacer I speak of right there where the 17mm socket is (hence the attached rendition). I'm also not sure what you mean by "NVH". Regarding removing it.....upon replacing the mounting system, I found that the bolt that goes thru the bracket/spacer would not tighten and therefor could not be torqued. Upon removal of the bracket/spacer, the bolt would tighten and torque to the requited specifications.
Old Nov 27, 2025 | 07:41 PM
My rendition may be a mirrored, but you get the idea.
Thank you
Old Nov 27, 2025 | 07:57 PM
JRCivic1's Avatar
10 Year Member
Community Builder
I am very familiar with the 8G Si engine bay... my wifey owned a 2008 Si (FA5) for eleven years and then passed it down to my oldest grandson who drove it for nearly five more years. We loved that car. I have no experience with the SOHC 1.8L "mundane" versions of the chassis. NVH refers to Noise, Vibration, and Harshness... many mounts and brackets within the engine bay of all Honda/Acura chassis have bolt-on "weights" that counter/offset these potential NVH dynamics. Removing them may introduce some or all of these bothersome phenomenon. You can test the waters by removing the plate... and if you do not notice any ill effects, you can leave it off.
Old Nov 27, 2025 | 08:09 PM
Interesting that you should mention the weight, I was just texting my friend who was helping me work on it and I said "As much as I hate to, I'll call Honda tomorrow. Maybe they'll tell me it's some type of harmonic balancer or some ****.". We will get the lower torsion bar replaced this weeks end and see how it goes. Because the original bolt will not tighten I'm looking for a longer one if that will resolve that issue as I feel that the reduction in size of the bolt tip may be the issue. We shall see.
Old Nov 28, 2025 | 03:30 AM
Chrisfrom1986's Avatar
To center the bolt for proper alignment and not tear through the mount due to vibration. That's why its cast iron, not aluminum. Just put it back on.
Old Nov 28, 2025 | 02:12 PM
SOLVED. It's a balancer that Honda added after folks complained about shimmy in the steering wheel while driving. See bubble 1.
Thanks to all that participated.
- Rev -
accelelag
Jan 5, 2025 08:10 PM
slugzed
Jan 29, 2008 07:38 AM
XkjeldorX
Jun 21, 2006 01:49 PM
k24a4kid
Feb 13, 2005 03:49 PM
