Help me Identify Wire for No start issue
Old Nov 25, 2025 | 09:02 AM
TheYoster's Avatar
Default Help me Identify Wire for No start issue
I Have a question for you guys I discovered this wire under the dash and was wondering if you guys could help me identify it so I could reconnnect it.
My issue with my civic is I have a No Start, No Fuel pump Prime. I could hear the initial struggle with the car trying to stay on while I was driving and hear some obvious static noise coming from the driver side. The car cranks fine and Ive been trying all sort of things from checking ground to replacing dizzy (then Check for sparks), ECU, Fuel Pump, fuses. Last time I got it started was when I replaced the Starter Cut replay and it died after being on for a couples mins (Could heard some sort of fizzle to weaken fuel pump noise. Tried craking again and the car started until it died again until I could not start it anymore.
To Note: Unfortunately I only recently discovered this wire after I did all the wire above.
JDM C.A.R
May 9, 2010 04:38 PM
exz0n-.-
12
Nov 14, 2008 08:43 AM
ZCpwrdEK
Oct 15, 2005 05:25 PM
baphomet
Jun 6, 2004 09:23 PM
jarel
Dec 16, 2003 02:01 PM
