Please help idle surge 93 civic Cx D16Z6
Old Nov 24, 2025 | 05:23 PM
Sadcivicman's Avatar
Default Please help idle surge 93 civic Cx D16Z6
On initial startup it will idle at 3k rpm’s before dropping and surging around 1200-1900rpms. There is no CEL. I have verified there is no vacuum leaks, bled the coolant, I’ve replaced the iacv (twice just to make sure the first one wasn’t bad), I have also replaced: o2 sensor, map sensor, spark plugs, spark plug wires, fuel filter, coolant temp sensor. It has a skunk2 throttle body and intake manifold installed. I have also replaced the ecu because when I bought it, it had an ecu for an a/t when the car is manual. I have not had the ecu tuned but it was surging before I replaced the ecu. Any suggestions? With the iacv unplugged the idle no longer surges
Old Nov 25, 2025 | 07:12 AM
speedooo's Avatar
Default Re: Please help idle surge 93 civic Cx D16Z6
Loosen the bolts on the iacv and stick a piece of gasket material in between the iacv and intake manifold. Open the idle adjustment screw.
Those iacv's are so temperamental.
Old Nov 25, 2025 | 09:05 AM
okay so i tried that and the idle does stop surging but its still a little rough, especially when revving. Do you think a tune could fix it ?
Old Nov 25, 2025 | 01:20 PM
krehzz's Avatar
It stops surging when the iacv is unplugged??
I had a similar issue turned out to be the gasket between my throttle body and intake. Wasn’t a bad gasket just the wrong one.
also for me personally skunk2 seems to always generate problems when using their throttle body’s.
Old Nov 25, 2025 | 03:43 PM
yes it does stop surging when unplugged,
this gasket came with the throttle body but it is thick as hell so I think I will try a different one
Old Jan 3, 2026 | 03:52 PM
krehzz's Avatar
I don’t think the thickness will affect that. Just check and make sure the gasket covers the ports.
Riot.eg6
Sep 6, 2024 02:28 PM
civicvx95
Sep 1, 2024 06:50 PM
ArchEnemyEJ1
26
Mar 23, 2016 08:28 PM
1990si
Dec 11, 2006 10:01 AM
VTECth1s
Jun 12, 2006 10:12 PM
