94 JDM H22A Accord P2T4 main shaft endplay
Old Nov 23, 2025 | 01:56 PM
oldskoolchris's Avatar
5 Year Member
Default 94 JDM H22A Accord P2T4 main shaft endplay
attempting to recondition the P2T4 transmission in my 94 JDM H22A Accord and unsure of the main shaft endplay and the shim formula. i have a copy of the workshop manual for the 97-99 Prelude with a M2Y4 in it which gives the specs as 0.004" - 0.006" and a formula for the shim. but google comes up with different specs for different searches and i can't find anything for any H22A transmissions here or on any other forums
and help very much appreciated
Chris
Old Nov 26, 2025 | 11:15 PM
97 Accord EX V6's Avatar
Loved
Default Re: 94 JDM H22A Accord P2T4 main shaft endplay
Originally Posted by oldskoolchris
attempting to recondition the P2T4 transmission in my 94 JDM H22A Accord and unsure of the main shaft endplay and the shim formula. i have a copy of the workshop manual for the 97-99 Prelude with a M2Y4 in it which gives the specs as 0.004" - 0.006" and a formula for the shim. but google comes up with different specs...
That external play number is small enough to represent the lip seal tolerance on the housing. Measure your clutch housing spring and come up with your midpoint. Use the same method for shim selection and you should expect the same tolerance regardless of the housing.
Old Nov 28, 2025 | 12:41 AM
5 Year Member
ok yep that makes sense. thanks very much
iNfAmOuS_E46
Dec 8, 2009 01:13 AM
irresistible nay
Jul 15, 2005 08:17 AM
94nvt
Jan 16, 2004 03:34 PM
prospeed
Mar 4, 2002 09:59 AM
