B16 series clearances question.
So currently we are again rebuilding my b16... due to some errors in the machine shop/ engine builder...
(This is not an all out build , daily that will see abuse and track use)
Now not sure what kind of pistons/rods I ll use..
The build parts are the following.
Toda A2 cams
Toda springs / gears
OEM retainers
OEM locks
OEM bearings.
Pistons/Rods (not sure yet)
CR target , 11.5:1 - 12:1
Stock Crankshaft.
PCT IM / B18C-R TB
Superspring header 4-2-1 (60mm) with 200 cel cat.
targeting around 200hp at the crank (the more the better) , rev limiter not sure yet , I assume that 9.5k will be enough and the power will start to taper off.
Are those clearances to give to my machinist correct?
ROD BEARING CLEARANCE: 0.0015" – 0.0018" (0.038 – 0.045 mm)
MAIN BEARING CLEARANCE: 0.0018" – 0.0020" (0.045 – 0.050 mm)
RING GAPS (81 mm bore): Top Ring: 0.018" – 0.020" Second Ring: 0.020" – 0.022" Oil Rails: As supplied (will adjust for bore)
CYLINDER HONING: Torque plate required Plateau hone finish 280–320 grit Target surface finish: RA 15–20
CRANKSHAFT: Polish journals Thrust clearance: 0.0020" – 0.0070"
RODS: Resize big-end if needed Measure big-end with ARP bolts torqued/stretched Side clearance: 0.008" – 0.014"
PISTON-TO-WALL CLEARANCE: 0.0025–0.0028" for 4032 / ~0.0030–0.0033" for 2618
VALVETRAIN: Following TODA instructions (not sure if it has any inside (assuming it does))
If those are enough to use with stock rods / pistons and can hold up that is even better. but not sure that is a smart idea.
Any input and your experience is greatly appreciated , thank you so much.
This is info that I gathered from all sorts of forums and mechanics / engine builders that have experience with b series.
I want longevity and reliability (the car wont live at 9.5k) but will get sort of abused.
Thank you again!
Toda A2 cams
OEM retainers
OEM locks
OEM bearings.
Stock Crankshaft.
PCT IM / B18C-R TB
Thank you again!
eg6noise
Aug 19, 2019 03:07 AM
bks84
Aug 21, 2007 10:12 AM
Hardt
16
May 24, 2007 07:14 PM
