I am buying a 2000 civic, it is very original and drives great. I did a compression test and it is 175 PSI in 4 cylinders.
However I noticed the spark plugs are little red/brown. Do you think is too rich and maybe cleaning the MAF and a tune up can resolve it or it is a head gasket problem? What do you think? It is a D16y8
That color is from running octane booster (or some type of fuel additive) or leaded fuel. It isn't because it is running rich... and you don't have a MAF sensor... you have a MAP sensor which operates totally different.
[QUOTE=DLR_civic2001;53011858]Hi guys, I am new here!
They ran Seafoam or some fuel system cleaner thru the gas tank, As long as they dont have oil or are black they will run fine
