Fuel tank straps
Old Nov 7, 2025 | 05:46 AM
gmd25m's Avatar
Default Fuel tank straps
1997 Civic HX, 5MT, stock, 315k miles
The original fuel tank straps have a rubber material on them on the side that has contact with the fuel tank.
All the current aftermarket fuel tank strap offerings that I have seen are just bare metal.
What is this rubber material ? What is the equivalent that I could put on a new set of aftermarket straps ?
Old Nov 7, 2025 | 06:41 AM
theYBLEGAL's Avatar
Loved
Default Re: Fuel tank straps
I hit google for ya. Luckily I could reuse mine when I did my tank a year or 2 ago. But I wondered.
There's some universal stuff out there I figured. Browse this website below to find the size that fits. I don't know measurements offhand, and you have stuff in front of you.
https://www.tanksinc.com/index.cfm/p...rod/prd413.htm
Can be bought at Summit https://www.summitracing.com/parts/tnk-sl24
Just search summit for the part # of the size you need, tho the one I found might be fine. Cut length with scissors
Old Nov 7, 2025 | 09:56 AM
gmd25m's Avatar
Thanks for the info. I did some searching myself but couldn't nail down exactly what you shared. What I came up with was "Butyl Mastic tape" which I went ahead and ordered before I saw your post.
There are also some black "pads" of some sort of rubber/deadening material on the top part of the tank. I am thinking the butyl mastic tape can be used for that too, I hope.
Old Nov 7, 2025 | 11:54 AM
theYBLEGAL's Avatar
Loved
The tape you speak of is soft. I use that stuff to seal wire connections on outdoor electronics. Its meant to form shape. Its not hard like you want. You need anti-abrasion protection.
Old Nov 8, 2025 | 09:56 AM
gmd25m's Avatar
Ok thanks again ! I appreciate the kmowledgable engagement. You have me going down a rabbit hole now haha. Please forgive my follow up questions.
The straps you linked to are a bit short per my measurement of the straps.
Looking at replicating those, what would you say is the best material to use
1) Butyl Rubber (you already ruled it out but putting it in here for completeness)
2) Natural Rubber
3) EDPM rubber (this is my briefly educated answer
4) Neoprene rubber
Thanks again in advance.
Old Nov 8, 2025 | 02:20 PM
theYBLEGAL's Avatar
Loved
No problem.
Instead of making them from scratch doing R&D, spend more time searching what's already available. Your time has to be more valuable than $20 on amazon. See link below, there's tons of universal options, 6ft long, cut to length, different widths. Keep it simple!
Amazon Amazon
Old Nov 8, 2025 | 02:25 PM
gmd25m's Avatar
No problem.
https://www.amazon.com/s?k=fuel+tank+strap+insulator
Funny thing I did that Amazon search already, those straps are for tractor trailers and are a bit larger than the 1" width I need (I measured the OEM straps). I may go that route but I have a couple days until the fuel tank arrives so just doing a bit more "analysis by paralysis" I guess.
One more thing, what is the diameter of the fuel filler neck vent hose, part number 17653-SH7-000 ? I ordered 5.5mm hose with the butyl tape because some ai search said it was 5.5mm hose, but that is actually the diameter of the part 17351-S04-A00 that goes to the vend valve.
POSonda
Nov 20, 2023 04:27 AM
onefstek
Welding / Fabrication
87
Mar 13, 2011 04:25 PM
pleej
Nov 5, 2010 07:06 AM
AK77
Oct 2, 2009 10:10 PM
hybrid2007
12
Feb 19, 2009 03:13 PM
