Honda Accord 2016- 2017 This is the place to discuss all things Honda Accord related for the 2016 -2017
2016 accord tire pressure,abs,traction control,power steering on at same time
Old Oct 7, 2025 | 07:12 AM
dctaz37's Avatar
10 Year Member
Default 2016 accord tire pressure,abs,traction control,power steering on at same time
We were driving along and all these warning lights came on at the same time. Where do I start troubleshooting?
Old Oct 14, 2025 | 03:11 PM
dctaz37's Avatar
10 Year Member
Default Re: 2016 accord tire pressure,abs,traction control,power steering on at same time
I picked up a scanner Autel Autolink AL619 (
" title="Amazon" target="_blank">Amazon
Amazon Amazon
. I bought all four replacement sensors in which the two rears are the same. Cleaned the hole many times as the new sensor was very hard to get it. It ended up breaking trying to get it in so I had to repeat the removal process. Cleaned a little more and eventually was able to install the second one I had. Now I get ABS sensor installed incorrectly error code 16-15. Any help please? Can you lube the outside of the sensor to get it in? I didn't want to wire brush/clean too much.
Old Oct 16, 2025 | 04:57 AM
sivicman's Avatar
I didn't know you could install it incorrectly. Doesn't the sensor only go in one way?
Old Oct 17, 2025 | 07:59 AM
dctaz37's Avatar
10 Year Member
That is what I thought as well. I tried another sensor, put it back together and same problem. Took the hub apart and found a ton of corrosion, see before and after pictures. Also the end of the bearing pack had a crack, should have snapped a picture. Put it back together and same error. I ordered a new hub as I don't know what else to do.
t else to do.
TWRuhe
Jan 28, 2009 10:15 PM
Hippie
Oct 15, 2002 07:05 PM
