Car overheating
A compression test should be done , It'll tell a lot , Things should be tested before spending money on parts you don't need , Is the exhaust whitish ? Is there white goop under the oil fill cap ?
When I did a comp. test on a 1.7 I tightened the gauge fitting too tight and had trouble removing it . Finger tight should be good enough . A few mechanics have said that once that gasket goes the coolant and crap circulates through the motor and never really gets cleaned out so a complete over haul should be done . But of course head gaskets are replaced all the time .
Oscar Ponce
Feb 26, 2012 11:15 PM
PearlWhiteAccord
Sep 25, 2002 12:15 PM
