Poor gas mileage
Old Sep 27, 2025 | 11:37 PM
Bert0717's Avatar
Default Poor gas mileage
I have a 2000 civic ex coupe with a 1.6l vtec, 5 speed manual transmission. And I commute to work and back and average of 40 miles a day all highway and some how im using up a half tank a day. What could be my issue. I've checked and there's nothing leaking at all.
the ac and powersteering have been deleted and the only upgrades done are stage 3 clutch and a cold air intake.
Old Sep 28, 2025 | 04:57 AM
captainblue92si's Avatar
Loved
Default Re: Poor gas mileage
Your 2000 Honda Civic EX Coupe with a 1.6L VTEC engine and 5-speed manual transmission should typically get around 30-35 mpg on the highway, based on its factory specs and real-world data. With a 11.9-gallon fuel tank, a half tank (roughly 6 gallons) should last significantly longer than 40 miles, so burning through that much fuel daily suggests an issue. Since you’ve confirmed no leaks and the car has minimal modifications (stage 3 clutch and cold air intake, with AC and power steering deleted), let’s break down potential causes for poor fuel economy.
Possible Issues
  1. Driving Habits and Conditions:
    • Aggressive driving (high RPMs, frequent acceleration, or running the VTEC range) can drastically reduce fuel economy. The 1.6L VTEC engine is efficient at lower RPMs but less so when pushed hard.
    • Short trips or cold starts, even on highways, can lower efficiency if the engine doesn’t reach optimal operating temperature.
    • Headwinds, heavy loads, or hilly terrain could also contribute, though you mentioned it’s all highway.
  2. Fuel System Issues:
    • Faulty Oxygen (O2) Sensor: A bad upstream O2 sensor can cause the engine to run rich (too much fuel), reducing mileage. This is common in older Civics and won’t always trigger a check engine light (CEL).
    • Dirty or Clogged Fuel Injectors: Deposits in the injectors can disrupt fuel delivery, leading to inefficient combustion.
    • Fuel Pressure Regulator: If it’s stuck or malfunctioning, it could cause excessive fuel delivery.
    • Cold Air Intake Issues: If the intake isn’t properly sealed or the air filter is dirty, it could disrupt the air-fuel ratio, causing the engine to run rich.
  3. Ignition System Problems:
    • Worn Spark Plugs or Ignition Components: Old or fouled spark plugs, worn ignition coils, or bad plug wires can lead to incomplete combustion, wasting fuel.
    • Incorrect Ignition Timing: If the timing is off (due to a slipped timing belt or improper adjustment), it can reduce efficiency.
  4. Engine Management and Sensors:
    • Mass Airflow (MAF) Sensor: A dirty or failing MAF sensor can misreport airflow, causing the ECU to inject too much fuel. Your cold air intake might also affect MAF readings if not properly tuned.
    • Throttle Position Sensor (TPS) or Manifold Absolute Pressure (MAP) Sensor: Faulty sensors can lead to incorrect fuel mapping.
    • Engine Coolant Temperature (ECT) Sensor: If it falsely reports the engine as cold, the ECU may enrich the fuel mixture unnecessarily.
  5. Mechanical Issues:
    • Low Compression: Worn piston rings or valves could reduce engine efficiency, though you’d likely notice power loss or rough running.
    • Brake Drag: Sticking brake calipers can create resistance, forcing the engine to work harder. Check if your wheels feel hot after driving.
    • Clutch Slippage: While your stage 3 clutch is new, improper installation or adjustment could cause slippage, increasing engine workload and fuel use.
  6. Tire and Alignment Issues:
    • Underinflated tires or poor alignment increase rolling resistance, reducing fuel economy. Check tire pressure (should be around 30-32 psi for your Civic) and alignment.
    • Aftermarket wheels, if larger or heavier than stock, could also hurt mileage.
  7. Exhaust System:
    • A clogged catalytic converter or restricted exhaust can reduce engine efficiency, though you’d likely notice reduced power or a CEL.
    • If you’ve modified the exhaust (not mentioned, but common with cold air intakes), an improper setup could affect backpressure and efficiency.
  8. Fuel Quality:
    • Low-quality or contaminated fuel can reduce mileage. Ensure you’re using the recommended 87 octane from a reputable station.
    • Ethanol blends (e.g., E10) slightly reduce mileage, but this alone wouldn’t explain your issue.
Diagnostic Steps
  1. Check Fuel Economy Accurately:
    • Reset your trip odometer, fill the tank completely, drive your normal 40-mile commute, then refill and calculate actual mpg (gallons used ÷ miles driven). This confirms if you’re truly using half a tank (6 gallons) for 40 miles, which would be ~6-7 mpg—extremely low.
  2. Scan for Codes:
    • Use an OBD-II scanner to check for pending or stored codes, even if no CEL is present. A failing O2 or MAF sensor might not trigger a light but can still affect fuel economy.
  3. Inspect Maintenance Items:
    • Spark Plugs: Check condition and gap (NGK or Denso recommended, gapped to ~0.044 inches).
    • Air Filter: Ensure the cold air intake’s filter is clean and properly installed.
    • Tires: Verify pressure and check for uneven wear suggesting alignment issues.
  4. Test Sensors:
    • Clean the MAF sensor with MAF cleaner, as the cold air intake may expose it to more debris.
    • Test the upstream O2 sensor with a multimeter or OBD-II live data to ensure it’s cycling correctly (0.1-0.9V).
    • Check the ECT sensor readings via OBD-II to confirm it matches actual engine temp.
  5. Inspect Mechanical Components:
    • Check for brake drag by jacking up each wheel and spinning it by hand (should rotate freely).
    • Verify clutch engagement feels solid, with no slipping under load.
    • Listen for exhaust restrictions or unusual noises indicating a clogged catalytic converter.
  6. Monitor Driving:
    • Keep RPMs below 3,000 during your commute to stay out of VTEC and maximize economy.
    • Use cruise control if available to maintain steady speeds.
Recommendations
  • Immediate Actions: Start with a fuel economy test, check tire pressure, and clean the MAF sensor. These are cheap and easy.
  • Next Steps: If no improvement, scan for codes and inspect spark plugs and the O2 sensor. These are common culprits in Civics.
  • If Needed: Consider professional diagnostics for fuel pressure, compression, or exhaust issues if simpler fixes don’t help.
Notes
  • Your mods (stage 3 clutch, cold air intake) shouldn’t drastically hurt mileage unless the intake is causing MAF issues or you’re driving aggressively to utilize the clutch.
  • The deleted AC and power steering should slightly improve efficiency by reducing parasitic drag.
  • If you’re calculating “half a tank” based on the fuel gauge, it might be inaccurate. Always confirm with a fill-up test.
(Grok AI via x.com)
Old Sep 28, 2025 | 07:59 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Grok AI isn't as smart as we all may think: There is NO MAF sensor on a 2000 Civic EX, so nothing related to this sensor is applicable.
Old Sep 28, 2025 | 09:19 PM
Kfmeden's Avatar
Good lawd. I wonder if the injectors are stuck/leaking with it dumping that much, and no visible leak. Pull the dipstick and give the oil a couple sniffs n see if it smells like straight gasoline.
Old Sep 29, 2025 | 08:47 AM
Bert0717's Avatar
I just changed the oil last night and the filter that was on it was to big and was causing a slight oil leak but other than that there's no leaks and it runs great side from the gas milage but I cant run the codes because the obd2 jack doesn't respond to the reader
Old Sep 30, 2025 | 02:20 AM
Chrisfrom1986's Avatar
@captainblue92si stop doing that. If someone wants to use chatgpt to try to fix their car that's one thing. Its another for you to blindly copy and paste whatever information is given by a terrible ai model. If you dont have first hand knowledge or have a link to correct information that's been posted there is no reason for you to post a wall of ai text. If you have any helpful commentary for the op please use your own words.
Old Sep 30, 2025 | 06:00 AM
Z31freak's Avatar
Did it happen before the "stage 3" clutch? Or after? Have you checked for the obd2 fuse to see if it's not blown out?
Old Sep 30, 2025 | 12:03 PM
zPandamoniumZz's Avatar
10 Year Member
I'd check if one of your injectors is jammed open.
Old Oct 4, 2025 | 06:05 AM
youstolemybeer's Avatar
5 Year Member
Are you getting a whiff of gas when you start the car? Take a rear wheel off, start the car and look for gas leaking/dripping under the car. The fuel tube (from the tank to the engine) could be rusted out and leaking as you drive. Had that problem and it drove me nuts. Checked everything under the hood with the engine running, dropped something on the ground, went to pick it up and looked under the car(engine running) and saw a drip. HUH took a flashlight and saw the drip of gas.
You wont see the drip with the engine off because the fuel pump has to pressurize the line
Old Oct 19, 2025 | 08:03 PM
Bert0717's Avatar
So after checking a few things I've came to realize im only getting 15 miles to the gallon. If I broke it down right cause I got 180 to a whole tank and it should be a 12 gallon tank and im not leaking anything from anywhere and no the stage 3 clutch was already in it but im about to have to change it again. And the fuse is good for the obd2 the wiring must be bad imma have to redo it does anyone happen to have the wiring schematics for the obd2 plug by chance. Oh and anther thing happening is my idle is running at 1600 rpms.im not sure why but thats probably the gas usage problem.
Old Oct 19, 2025 | 08:39 PM
JRCivic1's Avatar
10 Year Member
Community Builder
How about taking a pic of your ECU, with the ECU plugs visible and post it here. Also, what is the part number of the ECU plugged into the engine harness ? The part number begins with 37820.
Old Oct 26, 2025 | 04:44 PM
dlbucy's Avatar
I third investigating injectors. AutoZone rents a boroscope you could use to look inside your cylinders to see if there is gas in there. If you have the scope in there and turn the key to the on position to prime the pump (don't start it), you could see if fuel is dumping into the cylinders without even starting the engine. In my area, AutoZone rents tools for 90 days, and you get all your money back, including tax, when you return it. It's a pretty amazing deal. A fuel pressure test kit might also be useful for diagnosing injectors - you could check whether the pressure decays rapidly or stays when you prime the pump.
Another note, and this is going to sound really stupid, but are you sure your tank is getting full at the gas station? Sounds like you've filled up multiple times, so I kinda doubt that is your issue, but I once thought my car was leaking a massive amount of gasoline because I thought I filled up my tank all the way but didn't.
Old Nov 13, 2025 | 01:54 PM
Bert0717's Avatar
Quick update, someone informed me that if I had a constant 12 V current running, which by accident I did, because I had a amplifier, put in for a sub, and for some reason, they did not run a in line fuse nor a shutoff switch when jumping the remote wire from the power wire. Either way, though, I was told that if this was an issue, it would be possible that my injectors would stick open. And if I disconnected the constant flow, it may fix them. Does that sound plausible?Can anyone tell me this?Also , it's kind of off topic , but does anyone know if a 225/50/16 we'll entire with the same offset that the car is initially calls for would fit underneath with a factory suspension
Old Nov 13, 2025 | 08:34 PM
JRCivic1's Avatar
10 Year Member
Community Builder
It is unlikely that your amp remote wire connection is back feeding to your fuel injectors, but if you want to be sure, simply disconnect the amp wire at the end where it is connected to power (opposite end of the wire from the amplifier connection). Then re-check the engine operation. The tire size that you stated is way too tall as well as too wide... they will NOT work on the car.
Old Nov 21, 2025 | 05:09 AM
Deadpixle's Avatar
Even with a bad O2 sensor and me driving my GSR like I stole it everyday, it still averaged around 30 mpg. What do all your spark plugs look like?
Old Nov 21, 2025 | 06:19 AM
K7-1Ktrevor's Avatar
Loved
Community Favorite
no, your injectors are provided a constant 12v+ and triggered by a ground signal from the Ecu to pulse.
those tires are a 24.9” diameter, stock size is about 23”, doesn’t sound like allot but when you have a little motor it could make a big difference and that poor Sohc could be over worked from them.
i would calculate by hand your actual fuel economy, fill up, trip reset, drive to work and back, fill up again and do the math so you know exactly what mpg your getting.
also posting a pic of one of the spark plugs could go a long way as to helping to diagnose this.
Old Nov 21, 2025 | 07:01 AM
Deadpixle's Avatar
I put 17s on my 92 D15 civic and my fuel mileage went up. This is not it. Also don't just check 1 plug. You check all of them... You need to know if it's affecting 1 cylinder or all of them. If all cylinders look fine or are lean, than like mentioned above, you might have a fuel leak. If 1 cylinder is super rich, you probably have a bad injector.
Old Nov 21, 2025 | 08:26 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Also remember that if you are running a larger-than-stock diameter tire/wheel combination, your speedometer and odometer will run SLOW... so your actual fuel mileage will be affected from the math. The extra weight (as well as the weight being further from the moment of inertia) will make fuel mileage go down actually.
Brewbot87
May 6, 2013 07:15 PM
Simple_Sauce
Feb 18, 2008 06:55 AM
vtNaMeSe
Mar 21, 2004 12:11 PM
curveit
Nov 21, 2002 01:53 PM
Koori
Jan 15, 2002 07:06 PM
