99 accord electrical issue
Just somewhere to look if you have the knowhow to get in there.
Also you can check ground locations, make sure they are clean and secure. If you have or can get a Chiltons, it will list ground locations for the harness under the dash,
I'd also recommend double-checking your ground wires. As they age, the ground wires can often become loose or damaged, which might be the source of your problem. Hope this helps!
jsprice2
Oct 8, 2008 08:04 PM
