Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Aquired a 2005 civic. need help getting past a fuel pump relay click and red catalyti
Old Sep 17, 2025 | 10:39 PM
Carlos Berdeal's Avatar
Default Aquired a 2005 civic. need help getting past a fuel pump relay click and red catalyti
So i got a 2005 civic lx. It will fire up and idle. but it will click the fuel pump relay every 4 or 5 seconds with a hiccup in engine idle for a few minutes and then the click seems to subside. when you accelerate is hesitates but then the catalytic starts to glow red. If I remove the exhaust manifold from the equation, the relay hiccup still persists at startup and slows down but it still idles nice until i accel and it seems to be hiccupping. so no difference..
Computer has been changed and adapted to ignition key.
Compression on all cylinders is consistent.
If i disconnect the "power" to each spark module i get a definitive drop so i believe all spark modules are working. even if I swap positions.
ran it with no cat thinking cat was clogged but same outcome.
**problem connecting to the computer with obd scanner. it fails!!!**** Maybe this.....
Can someone please help me go in the right direction without just throwing money at the engine?
Also no gauges work.
Old Nov 14, 2025 | 11:35 PM
Ryan ricklin's Avatar
Default Re: Aquired a 2005 civic. need help getting past a fuel pump relay click and red cata
Hey did you redline the rpms? I did then knock sensor went out and then same problem idk what it is I've tried everything
Old Nov 14, 2025 | 11:36 PM
Oh check if it's still in time....and see if the timing belt is loose
Old Nov 19, 2025 | 02:29 AM
So I thought I'd share this to track down a ground and all power wires from under dashboard along chassis and engine bay....have fun son lol...oh website is......
https://autoelectronics101.com/index...iring-diagrams
Ryan43
Aug 6, 2022 12:06 PM
00TypeRCivic
Nov 19, 2013 04:35 AM
ej84dr
Jun 16, 2010 05:20 AM
TattoonistInk
Aug 17, 2008 10:56 AM
ZedEx
Jul 1, 2005 01:41 PM
