Check engine light help
Old Sep 16, 2025 | 01:21 AM
zeegee84's Avatar
10 Year Member
Default Check engine light help
I am facing some issues with my civic Si, rpm surge, high HC high CO emission failure, can't ready exactly what is the cel thrown.
Old Sep 16, 2025 | 08:22 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Check engine light help
You have codes 3, 5, 6, 7, 10, and 14 !!!
3 - MAP sensor
5 - MAP sensor
6 - ECT sensor
7 - TPS sensor
10 - IAT sensor
14 - IACV
I am shocked that your engine will even run with all of these codes... unless you have been unplugging various sensors while the key is ON just to test things... and you haven't cleared the codes generated after you plugged things back in. If you get all of the above codes natively/naturally... you have BIG problems.
Old Sep 24, 2025 | 09:27 PM
zeegee84's Avatar
10 Year Member
@JRcivic1
glad to see your reply, I am still confused with all thoses CEL still engine is running but not to its peak rpm is limited to 4000 due to ecu running in limp mode.
I don't know how to follow as the engine should never start with such cases, wiring has been checked point to point and its all good.
Old Sep 25, 2025 | 04:18 PM
NVturbo's Avatar
O.G. triple O.G.
Sounds like you plugged into the wrong sensors
double check the wire colors to match the appropriate sensor
Old Oct 11, 2025 | 02:21 AM
zeegee84's Avatar
10 Year Member
Double checked and confirm pin to pin, all wiring has been verified and its all good and ok, only observation worries me out now is the map sensor 3 clicks still persist however the TPS and MAP ground singal is conencted to D21 and 22 sensor ground while it is also connected to thermostat ground at the body.
When i remove that part the fuel priming and main relay stops working taking ground from that thermostat body
I am a bit confused would i have to separte common ground for sensors to D21 and D22 only and remaining can be grounded through thermostat body ?
Old Oct 12, 2025 | 12:19 AM
Wile E Coyote's Avatar
I am pretty sure MAP is grounded directly through ECU, not on a common ground at thermostate housing for this very reason.
Old Oct 31, 2025 | 02:32 AM
zeegee84's Avatar
10 Year Member
I did detail inspection on it only issues presist is the map sensor cel 3. car starts up find after 5 seconds check engine lights comes out and rpms shoots up from 1k to 2k rpm.
tried to change map sensor but still the same response tried changing the ecu still the same fault. really confused now
01_civiclx
Honda Civic (2001 - 2005)
Aug 22, 2024 05:08 PM
jonesEK
Feb 1, 2011 06:30 PM
99gsrboosted
Apr 13, 2007 06:44 PM
