Using Da rear knuckles on 89 hatch si
I have DA rear knuckles laying around and i want to put them on my hatch, can i use the 89 hatchback si parking break cable or do i need to use a different one? And can i use the same brake lines?
You will want to use Integra or 90–91 Civic Si e-brake cables, since the stock ones don’t line up well. Brake lines can usually be reused if the fittings match, just make sure they’re routed cleanly and get an alignment after the swap.
Thanks! Ill see which i can source locally the easiest. I planned on doing an alignment when i was done. Its currently getting a big overhaul on alot of overdue wear and tear.
civicgen3
Apr 23, 2008 12:19 PM
