About to remove my head
I went to do a valve adjustment on my 98 civic hatchback (D16Y7) and I think I buggered my timing when I accidentally rotated the engine backwards two full revolutions.
I went to turn over the engine after putting everything back together but when I went to turn over the engine it was running but extremely roughly. I only ran it for a couple seconds. Did I bend my valves?
It’s possible you didn’t bend your valves, but rotating the engine backward two full revolutions on your 1998 Honda Civic Hatchback (D16Y7) could have caused the timing to go off, leading to the rough running you described. The D16Y7 is a non-interference engine, meaning the pistons and valves don’t occupy the same space during operation, so turning the engine backward is unlikely to cause valve damage from piston contact. However, let’s break it down and address your concern.
Why the Engine Ran Roughly: Rotating the engine backward two full revolutions (720 degrees) likely misaligned the camshaft and crankshaft timing. The timing belt or related components may have slipped or been misadjusted during your valve adjustment, causing the engine to run poorly. Here are the likely culprits:
Steps to Diagnose and Fix: To confirm whether your valves are okay and fix the rough running, follow these steps:
- Timing Belt Misalignment: The timing belt may have jumped a tooth or two, throwing off the camshaft-to-crankshaft synchronization.
- Incorrect Valve Adjustment: If the valve clearances were set improperly, it could cause poor combustion, leading to rough running.
- Distributor/Camshaft Timing: Rotating the engine backward might have affected the distributor or ignition timing, especially if you didn’t reset the timing properly.
- Other Factors: Loose connections, disturbed sensors (e.g., crankshaft position sensor), or issues during reassembly could contribute.
- Stop and Do Not Run the Engine Further: Avoid starting the engine until you verify the timing to prevent potential damage or further issues.
- Check the Timing Belt Alignment:
- Remove the timing belt cover.
- Set the engine to Top Dead Center (TDC) on cylinder 1 by aligning the crankshaft pulley mark with the pointer on the timing cover and ensuring the camshaft pulley “UP” mark is at the 12 o’clock position.
- Verify that the timing belt hasn’t jumped teeth. The camshaft and crankshaft marks should align perfectly as per the service manual.
- Inspect Valve Adjustment:
- Recheck the valve clearances using a feeler gauge. For the D16Y7, typical valve clearances (when cold) are:
- Intake: 0.007–0.009 inches (0.18–0.22 mm)
- Exhaust: 0.009–0.011 inches (0.23–0.27 mm)
- Ensure all valves were adjusted at TDC for each cylinder during the initial adjustment.
- Inspect the Timing Belt and Tension:
- Check for wear, damage, or looseness in the timing belt. A loose belt could have caused it to skip.
- If the belt looks worn or damaged, replace it.
- Check Ignition Timing:
- Verify the distributor is correctly aligned. Rotating the engine backward might have affected ignition timing.
- Use a timing light to confirm the ignition timing matches factory specs (typically 12° ± 2° BTDC for the D16Y7).
- Compression Test (Optional):
- If you suspect valve damage (unlikely), perform a compression test. The D16Y7 should have compression around 135–155 psi across all cylinders, with minimal variation. Low compression on one or more cylinders could indicate bent valves, but this is unlikely in your case.
- Reassemble and Test:
- Once timing and valve clearances are verified, reassemble everything.
- Start the engine and listen for normal operation. If it still runs roughly, check for error codes using an OBD2 scanner or inspect for vacuum leaks or sensor issues.
- Rotating Backward: Turning the engine backward isn’t ideal but shouldn’t cause catastrophic damage in a non-interference engine like the D16Y7. The timing belt or distributor timing is the most likely issue.
- Service Manual: Refer to a Honda Civic service manual for exact timing marks and procedures. Online forums like Honda-Tech or Civicforums may have detailed guides for the D16Y7.
- Tools Needed: You’ll need a socket set, feeler gauges, a timing light, and possibly a compression tester.
ALL Honda 4-cylinder engines since 1988 ARE Interference Engines. The D16Y7 Natively rotates "Counter-Clockwise".
OP, you stated that you "accidentally rotated the engine backwards"... does this mean that you turned the crank pulley Clockwise or Counter-Clockwise ?
beaglemaster
K Series
Dec 27, 2023 08:30 PM
EFWhite
11
Jan 4, 2010 05:46 AM
mrfisher
Nov 16, 2005 09:46 AM
