Locating electrical ground bolt in trunk
Old Sep 10, 2025 | 03:19 AM
Farquea's Avatar
5 Year Member
Default Locating electrical ground bolt in trunk
I have an issue whereby both reverse lights are working but only with a single bulb in at a time, if both have bulbs then only one light works. My research has pointed me to the ground wire being the culprit and to inspect the bolt in the trunk where the ground connects. I'm seeing conflicting information as to where this bolt is though. I think it's behind the trim in between both light assemblies but if someone could confirm, I'd appreciate not potentially having to pull extra pieces of trim off looking for it.
Old Sep 10, 2025 | 06:53 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Locating electrical ground bolt in trunk
The ground is located center of the trunk, underside of the shelf.
Old Sep 10, 2025 | 08:58 AM
Farquea's Avatar
5 Year Member
I wish I could zoom out on this because that image is throwing me somewhat. When you say the 'shelf' is that the inside of where the "Civic" reflector/garnish plate is on the outside?
Hybrid94Hatch
Dec 1, 2011 09:18 PM
GsDAteg
Oct 10, 2007 01:55 PM
vinuneuro
Aug 30, 2007 01:38 PM
sinfulj32
Suspension & Brakes
14
Apr 14, 2006 11:58 PM
