1997 CRV Master Cylinder w/ABS Info
I have owned four Gen 1 CRV's, including the one which I used to write the Chilton's book, and at 364,000 miles the master cylinder failed. They are hard to find and expensive and I couldn't find a rebuild kit. Please take note, Amazon lists one but read the fine print as it states, not for models with ABS. This information is what I could find, a 1997 Honda CR-V with 4-wheel ABS uses a brake master cylinder with an OEM number like 46100S04N53 (or compatible equivalents such as M390402), featuring a 15/16 inch bore diameter, two outlets, and typically includes the reservoir and sensor for the ABS system. Just a quick note on this car, it has the factory bumper mounted accessory fog lights!
adrenalize
Honda Civic (2001 - 2005)
Jul 6, 2019 12:36 PM
crazyhouse2011
Nov 13, 2014 02:22 PM
spooncivic1
May 3, 2006 09:38 PM
