Anyone versed or experience with apexi afc neo?
Old Sep 1, 2025 | 04:29 PM
mr_ej's Avatar
Default Anyone versed or experience with apexi afc neo?
Title, need advice and help with dealing with this afc neo. i’m well aware that piggyback ecus such as this are heavily looked down upon in tuning. If it was simple as pulling a plug id happily do it and get rid of it and set my car back to stock. Unfortunately the neo has 17 wires all individually wired and god knows what would happen if i ripped it out.
Now to my issue at hand, b18b1 swapped 1994 civic from a 97 integra. I’ve driven the integra completely fine before swapping the motor in, so I can almost guarantee anything directly related to the engine is in order, timing, sensors etc., but of course taken with a grain of salt since i’m no expert.
Now car starts, and the cold start idle pattern is really weird, but i’m focusing on the operating temp idle, the second the car hits operating temp, the car idles between 4-600 and sounds like a chopped v8, which it obviously shouldn’t.
But I took it on a drive to see what would happen, and god that was a nightmare. RPM sticking, keeping steady foot on the throttle and rpm jumping, putting my foot the floor and almost no power it was nearly impossible.
So i know my tps sensor is in order as the voltage is correct 0.5 no foot, 4.5 WOT. Also checked my iacv by unplugging it and the engine died which means the iacv is in good working order. So at this point Im 99% sure that this afc neo is the root of these issues, so where do i go from here? Thanks
Jose Saucedo
Jan 12, 2017 07:36 AM
My97Prelude
Aug 8, 2008 01:52 PM
mikeunreal2
Feb 24, 2006 05:25 PM
Apocolipse269
Jan 6, 2005 08:32 AM
