rear wheel hub not fitting
Old Aug 28, 2025 | 07:17 PM
Jamesr36's Avatar
Icon4 rear wheel hub not fitting
i have a 98 civic hx non abs car and im trying to change the rear wheel hub and the ones i have order from detroit axle do not fit and the only differences i noticed were the bearing styles from the ones i had to the new ones. The bearings on the inside of the hub are hitting a lip on the spindle and all the research ive done shows the only difference in ek hubs is abs and non abs. im just at a lost done way to much to this car for a wheel hub to stop me. Any help would be appreciated
Old Aug 29, 2025 | 03:41 AM
hondamark35's Avatar
Default Re: rear wheel hub not fitting
the part in the red box is the old inner ring from the original hub. that needs to come off. (rusty area is the spindle)
I like to go at it with a 4" cut off wheel at an angle (see blue line) until about half the depth then hit it with a cold chisel until it cracks through. should slide off then. or if you have a puller that will grab it that could work.
Old Aug 29, 2025 | 05:57 AM
Jamesr36's Avatar
Thank you I had wondered if something like that was happening i appreciate the help.
Old Aug 29, 2025 | 06:57 AM
zPandamoniumZz's Avatar
10 Year Member
That inner race from the bearing is going to be a b***h to remove. I had to cut a slit with a grinder. Smack it loose with a hammer and chisel.
bruh guy
Apr 18, 2023 10:07 AM
baummy
Suspension & Brakes
Apr 13, 2018 10:12 AM
Darsholn
Aug 7, 2011 05:03 PM
EgonzEk
Feb 23, 2011 10:59 PM
dat_flip
Jul 12, 2004 09:40 PM
