What is this?
Old Aug 26, 2025 | 03:20 PM
Zmelli's Avatar
5 Year Member
Default What is this?
I have a 1995 Honda Accord LX. What is this part called? It appears to be leaking. Is this a major issue?
Old Aug 26, 2025 | 04:17 PM
Micro1989lxi's Avatar
Loved
Community Favorite
Default Re: What is this?
Is that just a wire that pushes on to a temperature sensor?
That looks like a brass sensor screwed into the block.
I think it is being dripped on or collecting oil, rather than leaking oil.
Old Aug 26, 2025 | 04:32 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
That usually is caused by oil dripping from the distributor seal.
Old Aug 31, 2025 | 02:15 AM
RC Perspective's Avatar
100% this.
If you have oil inside the distributor, the internal seal needs to be replaced; the leak on the coolant temp sender is from the external distributor o-ring.
Old Sep 29, 2025 | 06:36 PM
01_F23A1's Avatar
From what I have been seeing the internal seals aren't replaceable. Mine leaks too, been putting off buying a new distributor.
Old Sep 30, 2025 | 03:27 AM
Incorrect. They are servicable from 1976-2002, with the kit posted below. Both internal and external coil units.
I have replaced the inner seal on two of them.
They sell a kit specifically for this.
https://www.autozone.com/ignition-tune-up-and-routine-maintenance/distributor-housing-seal-kit/p/dorman-distributor-housing-seal-kit-917-136/746860_0_0?spps.s=4999
Same process as this,
https://honda-tech.com/forums/honda-...l-seal-3283719
For what it's worth, that information was not very hard to find.
Last edited by RC Perspective; Sep 30, 2025 at 07:23 AM. Reason: Restructured post
Old Oct 9, 2025 | 03:54 PM
pasadena_commut's Avatar
10 Year Member
I serviced the one in our 1998 Accord EX (4 cyl). There were two complications. The first was getting the right size O-ring for the inner seal, and I guessed wrong the first time and had to get a different size and do it again. The second is that on that particular distributor there is a pin which must be pressed out and pressed back in. It wasn't like in the linked video where the pin just fell out.
https://honda-tech.com/forums/honda-...butor-3367043/
To get that pin out I used one of these:
https://www.harborfreight.com/heavy-...ker-66488.html
and to put it back in parts from the above device and a big C clamp. Because the HF device wouldn't open wide enough fit the part and the pin in.
Old Oct 9, 2025 | 04:06 PM
Yes, the part that locates the distributor shaft to the camshaft is usually held in by a roll pin, and there is usually a retaining ring to prevent the roll pin from coming out.
The roll pin can be tapped out with a small punch and a hammer, and the external ring can be removed carefully with a small flathead screwdriver or a small pick.
The mixup with the oring size can be avoided by buying the kit linked above, commonly available at all the chain parts stores, which includes the correct oring and 2 internal seals that differ slightly on the ID size.
They sell the kit because once the oring hardens and starts to leak, not long after the internal seal will start to leak as well.
derekk24
Apr 1, 2017 06:59 PM
Vasil_Accord
Mar 27, 2017 05:54 PM
Mzcountry82
Sep 24, 2015 09:31 AM
njn63
Feb 23, 2006 12:41 AM
