Can someone confirm the ac oil capacity in a '96 Accord LX please.
Old Aug 25, 2025 | 04:39 PM
ozziegn's Avatar
Default Can someone confirm the ac oil capacity in a '96 Accord LX please.
Some sources say the '96 Accord LX 2.2L holds 5.5 ounces while other sources say it holds 8 ounces. Can someone here confirm which it is?
Old Aug 25, 2025 | 09:47 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Can someone confirm the ac oil capacity in a '96 Accord LX please.
5.5 sounds right, I don't have any books in front of me. This would be for a fresh system.
I *thought* it was noted on the silver foil A/C tag on the rad support.
Old Aug 26, 2025 | 06:06 AM
ozziegn's Avatar
Here's the label and it doesn't show the oil capacity. Like I said, most of the info on Google shows my capacity to be approx 5.5 ounces. I then found a couple sources that said like 8 ounces. I had to redo my entire system because I screwed up the first time when I installed a new compressor but I didn't balance the oil level(s) from the old compressor to the new compressor. Instead I had way too much oil and it was affecting the cooling capacity. I took everything down and I flushed my evap core and I replaced the drier and condenser with new ones. I put like 5.2 ounces of oil in my compressor (after I drained it) and I put .3 ounces in my evap core. Now everything works great but I'm paranoid that my current 5.5 ounces of oil might not be enough.
Chuck Parlier
Jun 21, 2023 07:39 AM
Wrens
Jun 10, 2015 11:48 AM
Clif
Feb 18, 2012 07:06 AM
