Crank No Start Issue
Hello, I just bought my first Honda civic 1999 5 spd manual DX Coupe, I bought it 2 n a half hours away, as I was driving back home, it the car died on the highway, 1 and a half hours. I also filled up my tank to full. the rpm’s dropped, I don’t really remember if it worked when I try to give it gas when the rpm’s were dropping, but it slowed down and eventually I turned off the car. but when I tried to crank it, it just cranked and didn’t start.
i tested the battery, it’s 12.5 volts, I changed the fuel pump and the fuel filter, I put the stock one back on as I bought one from autozone and advanced auto parts and both leaked bad :/
I also bought new spark plug wires and put it in the right order, I also topped up the engine oil, I do not know what is the issue at all, can somebody please help
me as this is my first time with a civic.
also I have no check engine lights or anything like that on the dash.
Since the car cranks but won’t start, the issue is likely related to one of the three essentials for an engine to run: spark, fuel, or compression. The lack of a CEL suggests the ECU isn’t detecting a major sensor failure, but some issues (like ignition or mechanical problems) may not trigger a light. Let’s go through the possibilities.
Step-by-Step Diagnosis:1. Verify Spark
Since you replaced the spark plug wires, let’s ensure the ignition system is delivering spark to the plugs.
You replaced the fuel pump and filter but reverted to the stock pump due to leaks. Let’s ensure fuel is reaching the engine.
If spark and fuel are present, the engine may not start due to a loss of compression, often caused by a timing issue.
Since there’s no CEL, major sensor failures (e.g., crankshaft position sensor) are less likely, but let’s rule out other electrical issues.
Recommended Next Steps:
- Check spark plugs:
- Remove a spark plug (any cylinder, e.g., cylinder 1).
- Inspect it for fouling (black soot, wet with fuel, or oil). If it’s wet, it could indicate fuel is reaching the cylinders but not igniting.
- Reconnect the spark plug to its wire, ground the plug’s metal body against the engine block (use insulated pliers to hold it), and have someone crank the engine. Look for a strong blue spark.
- No spark or weak spark? Suspect the ignition coil, distributor cap/rotor, or igniter (ignition control module). For a 1999 Civic DX (D16Y7 engine), you likely have a distributor-based ignition system.
- Inspect distributor:
- Remove the distributor cap and check for cracks, carbon tracking, or corrosion on the contacts.
- Check the rotor for wear or burning.
- If you have a multimeter, test the ignition coil’s primary and secondary resistance (primary: ~0.6–0.8 ohms, secondary: ~12–18k ohms, but check a service manual for exact specs).
- A common failure in 90s Civics is the igniter (ICM) inside the distributor. If spark is absent, this is a prime suspect.
- Why this matters: The car dying suddenly while driving and not restarting points to an ignition issue, especially since you’ve addressed fuel delivery.
- Check fuel pump operation:
- Turn the key to the “ON” position (don’t crank). Listen for a 2-second hum from the fuel pump (near the gas tank). If you don’t hear it, the pump may not be priming.
- Check the main relay (under the driver’s side dash). This relay controls the fuel pump and is a common failure in 90s Hondas, especially in hot weather or after long drives. A faulty main relay can cause the pump to stop working, leading to a stall and no-start condition.
- Inspect fuel pressure:
- If you have a fuel pressure gauge, connect it to the fuel filter’s banjo bolt (you’ll need a 1999 Civic-specific adapter). The pressure should be around 38–46 psi with the key ON and engine off.
- If no pressure, check the fuel pump fuse (Fuse #9, 15A, under-hood fuse box) and the pump’s wiring/ground.
- Fuel quality:
- Since you filled up before the issue, consider if the gas was bad (e.g., contaminated with water). This is less likely but possible. If you suspect this, drain the tank and refill with fresh gas from a reputable station.
- Why this matters: A failing main relay or fuel pump could cause the car to stall and not restart, especially after a long drive when components heat up.
- Inspect timing belt:
- A 1999 Civic has a timing belt, and if it slipped or broke, the engine could lose compression, causing a stall and no-start. Since the D16Y7 is a non-interference engine, a broken belt won’t cause catastrophic damage, but it will prevent starting.
- Remove the upper timing belt cover (near the camshaft pulley) and check if the belt is intact and properly tensioned. Have someone crank the engine (briefly) to see if the belt moves.
- If the belt is loose or off, the timing is likely off, preventing combustion.
- Compression test:
- If you have a compression tester, check each cylinder. Expected readings are ~135–180 psi (check a service manual for exact specs). Low or no compression in all cylinders suggests a jumped or broken timing belt.
- Why this matters: A timing belt issue could explain the sudden loss of power and no-start condition, especially if the belt slipped during highway driving.
- Battery and charging system:
- 12.5V is okay for a resting battery, but during cranking, it should stay above 10.5V. If it drops too low, the ECU may not function properly.
- Check battery terminals for corrosion or looseness. Clean and tighten as needed.
- Verify the alternator is charging (13.5–14.5V with engine running, if you can get it started).
- Grounds and wiring:
- Check the engine ground strap (near the thermostat housing or transmission). A loose or corroded ground can cause weird electrical issues.
- Inspect wiring to the distributor and fuel pump for damage or loose connections.
- Main relay (again):
- Since it’s a common issue, tap the main relay gently while trying to start the car. If it starts briefly, replace the relay (OEM or high-quality aftermarket, ~$50–80).
- Clogged exhaust:
- A blocked catalytic converter or exhaust can cause power loss and stalling. If the exhaust is clogged, you’ll hear little to no flow from the tailpipe when cranking. Tap the catalytic converter (when cool); if it rattles, it may be broken and clogging the exhaust.
- ECU issues:
- Rare, but a failing ECU could prevent starting without triggering a CEL. Check ECU fuses (under-hood fuse box) and inspect the ECU (behind the passenger kick panel) for water damage or burnt smells.
- Immobilizer (if equipped):
- The 1999 Civic DX typically doesn’t have an immobilizer, but if retrofitted, a failing key or immobilizer module could prevent starting. Confirm if your car has an aftermarket alarm or immobilizer.
- Test for spark (as described above). If no spark, focus on the distributor (igniter, coil, cap, rotor). A used OEM distributor from a junkyard ($50–100) or a new igniter ($40–70) may solve it.
- Check fuel pump operation and main relay. If no hum from the pump, test the relay by swapping with a known-good one or bench-testing it.
- Inspect the timing belt. If it’s loose or broken, you’ll need to replace it (~$30–50 for a belt kit, plus labor if you can’t DIY).
- If spark and fuel are confirmed, perform a compression test to rule out mechanical issues.
- Check grounds and fuses for quick wins.
Rappaface
25
Oct 13, 2022 09:34 PM
ready2burnit
14
Nov 9, 2015 10:12 AM
85turbottype
Dec 28, 2010 07:58 AM
