Can I use a f22 vehicle speed sensor on a h22 trans?
Old Aug 22, 2025 | 01:49 AM
SoldierMan's Avatar
Default Can I use a f22 vehicle speed sensor on a h22 trans?
I have a 96 accord with a bad f22 transmission and i've acquired an h22 trans out of a 95 prelude (mp1a).
The prelude trans has no VSS installed( they come with PS lines attached, people cap them for the swap to f series)
I want to use my F22 VSS in the new H22 transmission to save myself 140$. The F Series VSS has no PS lines attached.
Will it (f22 vss) go into the trans(h22) and display correct speed?
The parts both look nearly identical besides the 2 PS lines that feed into the prelude VSS.
Any info or best guesses would be appreciated.
Prelude vss h22
Prelude vss h22 ^^
Accord vss f22
Accord vss f22^^
Old Aug 23, 2025 | 08:31 AM
Aradin's Avatar
Premium Member
Default Re: Can I use a f22 vehicle speed sensor on a h22 trans?
Yes. If you're more comfortable using the Prelude sensor, you can just fill it with powersteering fluid and add a little loop with a piece of rubber hose on the two fittings.
crxses
Jan 10, 2011 01:49 AM
honda3x23
Jul 26, 2006 11:42 PM
deucedeuceEK
Jun 26, 2006 09:28 AM
jdmcivicferio
Mar 9, 2003 01:31 PM
