Emergency. Shoes are stuck in drum in process of changing them
Old Aug 15, 2025 | 06:01 PM
JCTyler's Avatar
Default Emergency. Shoes are stuck in drum in process of changing them
I need to remove the drum.When removing brake drum to replace shoes, 2 pins that hold the shoes snapped and are floating inside drum. What can be done about this to remove them? This is my daily driver so I need to resolve this ASAP.
Old Aug 16, 2025 | 05:24 AM
Ryanthegreat1's Avatar
Default Re: Emergency. Shoes are stuck in drum in process of changing them
Did you back off the adjusters?
Old Aug 16, 2025 | 08:41 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Looks like a Canadian car... I would order a pair of salvage yard trailing arms (drums or discs if you want to upgrade) from a vendor in either California, Arizona, New Mexico or a Southern state like Mississippi or Alabama. What you have pictured isn't worth fixing.
Old Aug 17, 2025 | 09:05 AM
Heysoos's Avatar
Loved
Community Favorite
Agree with this sentiment. I recently just replaced my rear drums and shoes, and even though I’m not plagued by rust, they’re such a a PITA, and produce so much brake dust, it convinced me to upgrade to rear discs. Haven’t done the conversion yet, but very much looking forward to it.
I hope backing off the adjustment has allowed you to remove them anyway.
Old Aug 19, 2025 | 08:30 AM
JCTyler's Avatar
I got them off with a few hammer taps. Old drums weren't damaged but will get some new replacements.
Old Aug 28, 2025 | 10:28 AM
jinVI's Avatar
When in doubt, hammer it out!
If anything like this happens again or if this might help someone else: You can also use the shoe spring adjustor, accessible through a hole on the face of the rotor. It's a little gear attached to a spring mechanism that you can tighten or loosen with a flathead. See diagram below.
.Slug
12
Aug 4, 2006 02:36 PM
vinuneuro
Apr 15, 2006 01:39 PM
civicd15b2
Mar 29, 2005 02:40 PM
VividBlueFit
Oct 27, 2003 02:42 PM
97 CIVIC EX
11
Nov 15, 2001 07:43 PM
