Need opinion I hear a rattling sound in my d16y7 manual when accelerating
Old Aug 11, 2025 | 08:50 PM
Rshaw410jdm's Avatar
Default Need opinion I hear a rattling sound in my d16y7 manual when accelerating
I changed the fluid when I got the car third gear would grind going in after fluid was changed it was like a miracle trans seemed fine but I'm now hearing a rattling while accelerating and deaccelerating in like first thru third but all gears can go thru them fine in the morning I hear a slight humming and when I push the clutch in the sound goes away and of course when the cars been running while I cant hear that noise much at all just rattling when goin thru first thru third should I drop a trans in n clutch n flywheel or just change clutch?
Old Aug 12, 2025 | 07:25 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Need opinion I hear a rattling sound in my d16y7 manual when accelerating
The trans definitely has issues... while you are changing that, inspect the clutch, flywheel, and release bearing and replace as necessary. It is easy to do while the trans is out... you are right there. Don't forget to check the rear main seal while you are at it.
Old Aug 15, 2025 | 07:06 AM
Heysoos's Avatar
Loved
Community Favorite
A very common issue on these is the input shaft bearing race breaking down. It’s made of plastic, so unsurprisingly, it fails after many miles of use.
LukeM
Oct 29, 2022 03:17 PM
ITR9
Jul 5, 2005 09:55 PM
RefuseRice
Oct 19, 2004 10:16 PM
Darren804
Feb 21, 2002 02:51 PM
