Looking for 2008 CRV floor jack
Hello-
I have been looking without success for specs on the height of a 2008 CRV jack. It seems like 1.5Ton to 3Ton/ 18 inch reach is the minimum.
I am looking for a jack to lift one or both wheels at a time to do brakes. I will use the emergency scissor jack as a jack stand.
My questions are:
Can you safely jack under the suspension arms with a smaller jack?
Are there extensions or will a block of wood work to allow smaller jacks to reach the center jack point and lift both wheels? (I'm not sure if extensions are safe.)
Thanks
My questions are:
Thanks
check the logic: ground clearance is 7.3". jack points aren't far above that- say 8". suspension droop from nominal is 5-6" so around 15" to get the tire off the ground is plausible.
very no. use a jack stand as a jack stand.
jack points:
Hello-
My questions are:
Thanks
My questions are:
Thanks
