Honda CR-V & Element 2WD & 4WD Element & CR-V
P2228 BARO sensor low voltage and open in ground wire
Old Aug 11, 2025 | 03:41 PM
OrangeToaster28's Avatar
Default P2228 BARO sensor low voltage and open in ground wire
2004 Honda Element EX
So I have a hard engine light on. P2228 BARO sensor low voltage. I only have identifix to my use. So based on searching the diag procedure for that code. They basically say to reprogram the ecm or replace it with a known good one. This is assuming the ecm is bad. So obviously I did my circuit testing to start with. I did end to end continuity test for the GN/WHT wire which is the ground wire from ECM to MAP sensor and its open. I was wondering if anyone’s experienced this before and possibly have common areas where the wire can break. To save time, I want to run a new wire to replace the broken one. I just don’t have any terminal part number information, if anyone can lead me to find that as well that’d be awesome. Thanks.
komet 163
Sep 4, 2024 09:39 AM
jjs14
Honda Civic (2001 - 2005)
Sep 11, 2020 05:23 PM
Chief!
Mar 1, 2012 03:03 PM
juanchoenuncrx
Aug 24, 2007 04:48 AM
