tune help
Old Aug 9, 2025 | 08:09 PM
dacodaquire's Avatar
Default tune help
can anyone help me out or point me in the right direction to, ive had the car/tune for 2 years now out of nowhere the a/f shot down. idle used to be 14-14.7 now its 10.4-10.6 not really wanting to risk it so its a idle data log only atm
File Type: zip
Old Aug 9, 2025 | 08:36 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: tune help
What have you changed recently in the car ?
Old Aug 10, 2025 | 01:14 AM
nothing other than a head gasket, other than that absolutely nothing. Even bought new fuel pump, stable 50-55 fuel psi.
Old Aug 10, 2025 | 09:00 PM
JRCivic1's Avatar
10 Year Member
Community Builder
So, you haven't changed anything... except a head gasket and a fuel pump. That means that you actually changed TWO things !!! Is the fuel pump the exact same part as you had before ? As for the head gasket... was the cylinder head surfaced ? Is the new head gasket the same thickness as the previous one ? Are you sure the engine is in proper mechanical time ?
Tunes don't change on their own... so, if you haven't made any changes to the tune, the reason for the dramatic A/F changes are a change in the engine. It is either something you have done OR something like a failing sensor that is altering the fuel delivery.
cornhusker
Sep 20, 2003 01:33 PM
