1992 Civic 4 dr sedan 1.5L
Old Aug 5, 2025 | 08:22 AM
junkbug's Avatar
Default 1992 Civic 4 dr sedan 1.5L ECU problems
Hello all,
I have a 1992 4 door civic sedan with a 1.5 l and an auto transmission. Lately, it will crank but not start. Two mechanic visits later I am told the ECU has water damage. I sent it to GoECU, but they returned it as not being repairable. So, what are my options now? Can I repair it? I do not need to worry about a warranty claim. Or should I look for an Ebay replacement? How will I know if I order the right one, or a good one?
Thanks.
Old Aug 6, 2025 | 12:57 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: 1992 Civic 4 dr sedan 1.5L
Source another P06 ECU and see if that is the issue. You don't have to buy one, just borrow one from a friend/neighbor to test.
It may be something simple such as bad ignitor, starter, etc if the other ECU isn't the culprit.
Old Aug 6, 2025 | 05:18 PM
junkbug's Avatar
Thank you for the advice. The second shop I took it to had it running on a technician’s ecu, but he wouldn’t sell it, the rpm limiter had been removed for racing.
Old Aug 6, 2025 | 07:41 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Bad ECU's are becoming more and more common. Buyer beware when purchasing from sellers outside of your local area.
Pharu21
Honda Civic (2016 - Current)
Nov 14, 2022 07:57 PM
andrew.anderson
Sep 27, 2005 11:19 PM
Turbo Powa
17
Jun 6, 2002 06:29 AM
