2002 crv crank no start(Fuel pump and spark working)
Hi I have a 2002 Honda crv LX and I’m having a crank no start issue. Parked the car a couple months ago and a week later it started the crank no start issue. So far I have replaced pcv valve and cleaned out the intake and Intake runner. There was quite a bit of oil in the runners, pcv valve, throttle body and even part of the intake. After cleaning it all out we checked the spark plugs which had slight corrosion and burnt and wouldn’t spark. We replaced with brand new ngk spark plugs and tested each coil and they all sparked upon crank. We also checked to hear the fuel pump priming and it is also priming. I’m not sure what else to check or do please let me know thank you.
also I checked every fuse and they are all good. Not sure how to Check those fuse black boxes tho will do that and update.
The "black boxes" are relays. You can check them with a relay checker, or an ohmmeter. That said, you may have a fuel issue. I suggest you check your fuel pump, sounds like it may have gone south on you.
Even if I hear the fuel pump priming it cañ still be bad ? Also where do I check if it’s even getting fuel pressure do I need a special guage or something
You can buy a fuel pressure tester on Amazon for around 20 bucks.
slash00R
Jul 30, 2002 03:54 PM
