Bent Front Jack point
Old Jul 13, 2025 | 02:15 PM
tmeijer68's Avatar
Default Bent Front Jack point
Where else in front of my 98 honda civic is it safe to use my jack if the area whet jack goes is bent.
Old Jul 13, 2025 | 08:19 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Bent Front Jack point
It isn't. You will need to use the side jack points just behind the front wheels instead. It is not uncommon for aftermarket core supports to be sub-standard in construction and bend easily under the weight of the car at the jack point on the front... this may be your issue.
Callofmine23212
May 27, 2024 01:23 PM
dwtkns
Apr 26, 2024 10:42 AM
Team Loyalty
Jul 22, 2018 06:50 AM
