1993 EG civic crank no start
Old Jul 12, 2025 | 09:22 AM
EGwilsonFK8's Avatar
Default 1993 EG civic crank no start
About a month ago I took the car out for a drive I then went to a store and turned the car off and when I went back it wouldn’t turn on anymore. I’ve changed the main relay and ignition switch but it still won’t turn on. I see that the check engine light stays on and when I wiggled the key it went away it turned on. I thought the ignition switch was the problem but I changed it and still nothing. Any help would be appreciated!
Old Jul 12, 2025 | 07:11 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 1993 EG civic crank no start
Bad ECU likely... the "key wiggle" was probably just coincidental.
Old Jul 12, 2025 | 07:33 PM
I’ll get that checked out thank you
raidacaipo
26
Aug 28, 2014 12:46 AM
My_EFsedan
30
May 16, 2013 05:32 PM
AyeYo
Jan 21, 2012 03:47 PM
blaxican05
Feb 23, 2008 08:47 PM
