ELD
Old Jul 5, 2025 | 07:34 AM
my97accord's Avatar
Default ELD
Can someone tell me if my car has ELD (Electrical Load Detector)? if yes, where is it located? I have a US 1997 Honda Accord LX 4-cylinder sedan.
I am trying to figure out why my Battery light pops up randomly for a second while driving on a hot day with AC on. I plugged a digital voltage display(with USB outputs) to cigarette lighter, the reading kept changing 12.7 - 14.5 depending on when stopped at the signal or while driving but stays steady at around 14v while idling. I am not sure if the display should always be at 14v or so when the car is on, a youtube video says if the voltage fluctuates, then it could be a ELD issue.
Vehicle history: Replaced starter(Refurb Denso) & Alternator(refurbrished Duralast from Autozone) last year.
Please advise.
Old Jul 5, 2025 | 08:28 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: ELD
The car has an ELD, it is integrated as part of the under-hood fuse/relay box.
The battery/charge light is more likely due to an alternator issue or belt tension/pulley issue.
Old Jul 5, 2025 | 08:30 AM
Aradin's Avatar
Premium Member
Default Re: ELD
That is the ELD operating as normal. It will cut the alternator output to approximately 12.6 volts under low load conditions for economy purposes.
Your issue is likely the Duralast alternator. Any parts store alternator you get is gonna be garbage. Look for a used OEM Denso unit off of eBay.
Old Jul 6, 2025 | 04:43 AM
my97accord's Avatar
Default Re: ELD
Thank you tech8 & Aradin, really appreciate your input.
BonsaiRay
Aug 14, 2021 05:24 AM
Alex Resendiz
Feb 15, 2021 12:59 PM
jpg16
Jul 30, 2014 09:52 PM
devildawg3267
Jun 30, 2013 11:47 AM
Getsch
Sep 9, 2012 08:50 AM
