Tired of tricky electrical diagnostics? The Innova 5420 powered circuit tester is here to change the game. This isn't just a tester; it's your new best friend for electrical work. With its spark-proof protection and built-in safeguards, you can test and power components with total confidence.
$10 Off Discount code:FORUM5420 Apply at checkout Experience Precision, Power, and Protection
No circuit is out of reach with the 5420! The versatile 45° swivel head allows you to easily get into those hard-to-reach spots making maneuvering around tight engine bays a breeze. You can apply power with precision, delivering 3V, 5V, or 12/24V directly to components for controlled and accurate testing.
Want to power on a fan, a light, or a relay? This makes component testing a snap—simply watch for the component's response to instantly pinpoint failures and narrow down the failure source by isolating and activating specific circuits.
Safety is paramount, and the Innova 5420 has you covered. Its safe power and grounding features include an integrated spark-proof design and a built-in circuit breaker that protects both you and your vehicle from shorts or overloads. Plus, the positive/negative LED indicators give you clear feedback, so you can work with confidence.
With its 10MΩ input impedance and internal circuit breaker, you can perform electrical diagnostics like a pro, all while keeping yourself and your vehicle safe.
Ready to revolutionize your electrical work? The Innova 5420 is the tool you need to diagnose and repair with speed, precision, and complete peace of mind.
