Honda Accord 2016- 2017 This is the place to discuss all things Honda Accord related for the 2016 -2017
Radio / head unit suggestion for 2017 Accord Touring?
Old Jun 20, 2025 | 09:35 PM
xThaJamesx's Avatar
Default Radio / head unit suggestion for 2017 Accord Touring?
Has anyone had luck getting a new radio/head unit for the 2017 Accord Coupe V6 Touring that actually has full compatibility with the side/rear camera, steering wheel controls, and TMPS calibration etc? If yes, which make and model radio did you use? The stock radio has been making crazy static sounds even with the radio turned off. I had to pull out the fuse to make it stop.
Old Mar 23, 2026 | 06:59 PM
Accordian123's Avatar
Default Re: Radio / head unit suggestion for 2017 Accord Touring?
Model Clarion Ph-3771
Did you ever get any response about your radio issues, did you get an aftermarket replacement?
My model is ph-3771, and this model largely suffers with STATIC starting somewhere around 30 minutes of use. My radio is just rebooting right after the HondaLink logo starts to go off….
I had to pull the underhood 20amp fuse.
Still researching my next course of action.
I did buy a used replacement and it worked fine for almost 25 days and then started exhibiting the STATIC issue.
Can I use the QY-5111 model (looks like it shares all of the same wiring harness except for GPS plugin) ?
This radio makes the car unsafe in the following ways… and Honda should do a mandatory recall because this is so wide-spread.
1)Static issues-
The static sound becomes deafening, distracting and will not stop even though you turn off the radio
2)Reboot issue-
You cannot control the radio and resultantly, the radio controls all of your rearview and right side safety cameras.
All mileage and maintenance functionaltiy ceases to function.
PLEASE… anybody with a repair document for the radio please share— I can attempt to go in and repair/replace the capacitors or other failed components so that I can restore the safety features to my car.
or —— any suggestions about what others have done or any success stories/advice to get Honda to replace these failed units…
Old Mar 23, 2026 | 07:18 PM
xThaJamesx's Avatar
I ended up buying XAV-AX6000 and a custom harness off eBay.
https://www.ebay.com/itm/Honda-Accor...iN8HXf9e0pprqw
1)Static issues-
2)Reboot issue-
Old Mar 23, 2026 | 07:26 PM
THANK YOU for your reply!!!!
This is driving me crazy…
Did the Sony model restore any or your steering wheel capabilities, camera (Rear\Right) functionality and (far-reach….)
hopefully some of the mileage and oil lifetime functionality ?
Thanks again
Old Mar 24, 2026 | 11:05 AM
roddrick's Avatar
Premium Member
5 Year Member
The issue with the audio unit is heat related. The aux fan is not working or has a damaged fin.
mpomp
Audio / Security / Video
Jul 24, 2017 10:59 AM
honda.girl.1991
Oct 8, 2013 06:07 AM
kingrukus
Dec 25, 2012 02:49 PM
