Can’t get the timing belt tensioner grommet installed
Old Jun 19, 2025 | 04:44 AM
myfavecoupe's Avatar
10 Year Member
Default Can’t get the timing belt tensioner grommet installed
Recently had my timing belt done and noticed they didn’t put this grommet back that goes over the tensioner bolt. Got one from a junkyard and couldn’t get it into place. Anyone have this issue before?
Old Jun 19, 2025 | 05:41 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Can’t get the timing belt tensioner grommet installed
Use a pick to push it in. If not, leave it alone.
Old Jun 19, 2025 | 07:42 AM
aw614's Avatar
10 Year Member
Loved
I had that issue and just gave up on trying to get it in.
Old Jun 19, 2025 | 08:29 AM
10 Year Member
Good idea thanks!
Old Jun 19, 2025 | 08:30 AM
10 Year Member
Good to know. I thought there was an issue with the bolt or something. Thanks
Old Jun 22, 2025 | 09:35 AM
Plutonodian's Avatar
Wipe the insertion edges of the grommet w vaseline & make sure you're installing the grommet dome in the direction facing you. The dome should be humped up over the bolt in the direction facing you. Doubt that it would even install if reversed. IDK if that's your issue, only that it might be. As others have said, using a tool to push the lip of the grommet over the edge of the cover will help. However I would first try it with something that doesn't pierce the rubber, whether it's a small screwdriver, a chop stick, or whatever.
Edited to add: warming the grommet in hot water may make it more pliable & easier to install.
by39
Jan 1, 2023 10:36 AM
Cripton805
Jan 9, 2022 07:15 PM
mattatchison
Jun 7, 2007 04:58 PM
95accordh22a
May 10, 2005 07:43 AM
