Very bad mistake
Old Jun 11, 2025 | 06:51 PM
Annoyingteenage's Avatar
Default Very bad mistake
I was putting back together my 99 ex b16 swap after some head work first time ever rebuilding a motor.
i filled my raiditator with fluid kept filling it and let the bleed valve open. But still my coolant wasn’t getting hot I got distracted by a limp mode condition and I think I over heated my engine it idles terrible. Checked cylinders they look fine on a scope. Will check again tomorrow.
engine b16 multi layer steel head gasket arp head studs upgraded eBay pistons
am I going to have to replace my bottom end what dose my mistake entail
Old Jun 12, 2025 | 02:18 AM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: Very bad mistake
Most likely its from the limp mode, check the injectors, re set the ecu and or calibration if you have hondata or something, I dont think you damaged the engine, check all the basics like timing etc.
Old Jun 12, 2025 | 05:16 AM
I have a Hondata ecu but It didn’t stop the engine I started up this morning it started but couldn’t accelerate at all and sat idling at under 500 rpm’s
I am at the point where I just want to sell the car for parts
Old Jun 12, 2025 | 10:26 AM
BOMBCRU's Avatar
Check tdc in case u jumped a tooth.
do compression test
Check plugs for fouling, limp mode usually runs rich.
Did u plane the head/block during rebuild?
Cupajoe
Aug 3, 2018 06:37 AM
flushsi
Jun 29, 2011 04:59 AM
JuStInKaSe
Apr 20, 2009 10:56 AM
reverieman1290
12
Mar 25, 2009 10:40 PM
