Honda CR-V & Element 2WD & 4WD Element & CR-V
AC Compressor Problems- Leaky Shaft Seal
Old Jun 4, 2025 | 07:53 AM
Jfrizz81's Avatar
Default AC Compressor Problems- Leaky Shaft Seal
Recently my AC had stopped blowing cold on my 2018 Honda CRV. The AC clutch engages however, i noticed that the rubber dampener has failed and is shredded. I believe the compressor may be seized too because if i try to turn the clutch in the center i can't get it to spin. I guess that may be the reason for the rubber dampener failing. I remove the clutch plate and noticed debris and what looks like oil residue. Does anyone know what a leaking compressor shaft seal would look like? I have attached the pictures of my situation. The dealership wants to charge me $450 for the diagnostic if it ends up not being the shaft seal.
AC Clutch
AC Clutch
Removed clutch and looks like an oily residue. Leak?
Rubber Dampener
Rubber Dampener
AZCR-V
Apr 23, 2018 07:58 AM
