Electrical issue
Old May 26, 2025 | 11:38 AM
Mr. Mike's Avatar
Default Electrical issue
When I press on the brake pedal in my 90 crx, the dash lights come on. What would cause this and how can I fix it?
Old May 26, 2025 | 01:11 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Electrical issue
There likely is a short (e.g., exposed wire touching another exposed wire) for the different circuits (brake lights vs dash lights). I don't see a common connector in the different circuits; so, you'll probably have to start visually checking along the Green/White (wire with green colored insulation and a white stripe running through it). The Green/White power wire starts at the brake switch and try to follow along different parts of the dash wiring.
Old May 27, 2025 | 11:23 AM
Mr. Mike's Avatar
Thank you! I'll look into that.
JacksonD
Dec 15, 2010 06:29 PM
KayOs
12
Apr 13, 2004 02:29 AM
1badrex
Aug 7, 2003 02:55 PM
