Honda CR-V & Element 2WD & 4WD Element & CR-V
How serious is a timing chain issue due to low oil?
Old May 18, 2025 | 03:51 PM
penny15club's Avatar
Default How serious is a timing chain issue due to low oil?
I love my car and I would do a lot to keep it on the road. 2006 Element. It's had a minor oil leak (or is burning oil) for a while now but I guess I let it go too long between topping it off/changing the oil (or the leak got worse). Was driving it the other day and it felt like the clutch was slipping on acceleration (it's a manual), so I got it towed. Had the clutch replaced in August 2024 so I thought it might be an installation issue/warranty fix. Turns out it was something else: the oil was very low and that messed up other things. I haven't actually gotten a chance to speak with the service tech yet so I don't know exactly where I stand. Is it possible that with new oil it will just be okay to drive again (as long as I keep the oil full)? Or is it guaranteed that there's permanent damage and the car isn't driveable until the timing chain, etc. has been repaired? What do you think I should do? 1. Pay out the nose for the Honda service center to repair as per their suggestion 2. Take it to a 3rd party repair shop where it might be cheaper, have them also address the leak.
Thanks for your advice!
Old May 18, 2025 | 05:42 PM
Ryanthegreat1's Avatar
Default Re: How serious is a timing chain issue due to low oil?
Was it actually low on oil? Was the oil light on? I think these have an oil light anyway.
Old May 18, 2025 | 05:56 PM
The oil light wasn't on but the engine light was throwing a code P1009 which is to do with the timing. I get seasonal codes living in Chicago when it gets too hot/too cold that are historically from the air exhaust sensors (one sensor is OEM one is aftermarket, I didn't know any better at the time to do both). But I trust that the oil was low and I've read that low oil can stretch/break the belt on these cars.
Old May 18, 2025 | 06:01 PM
Extended oil change intervals is what stretches the timing chains on these.
I would want to make sure the rest of the engine is healthy and not burning oil before spending the money on a timing chain replacement. These are also known to have defective cam lobes that are found when doing a timing chain or valve adjustment.
Old May 18, 2025 | 06:07 PM
P1009 isn't the typical code for stretched time chain.
P1009 might be related to low oil pressure or plugged up VTC screens. Again from poor maintenance.
CR-V Guy
26
Aug 15, 2024 06:17 AM
newyawkballa
Honda Civic (2001 - 2005)
11
Feb 15, 2010 08:00 PM
pl_masse
Honda Fit
Jun 18, 2007 03:53 AM
BoBo Racing
Aug 12, 2003 10:35 AM
