So there’s a issue been happening with my civic for a while tho beforehand it wasn’t a huge issue now it has turned into a big issue
so beforehand the car would sputter and mess with my rpm’s sometimes giving gas sometimes not giving any bit of gas and it would just sputter crazy
now the car is struggling to stay on even during idle it immediately dies when I try giving gas it Giving no gas at all to the car
I’m still pretty new to learning about civics so the help would be so kind I already changed distributor, spark plugs and wires and check the alternator and there is this wire I don’t know what it is so I hope the photo could help anything would help
That wire is for the vtec solenoid. Aka if its not hooked up, variable valve timing doesn't work and the engine doesnt make as much power or have as much efficiency (however it only affects the higher rpms).
Thank you so much would there be anything else messing with it the car say like anything else that could cause my rpm sputters or the car struggling to stay on even during idle?
Any CEL? First thing to do is find out what the computer (ECU) is seeing. Could be a lot of things, TPS, IACV, coolant temp sensor.. many possibilities..
