LEV to ULEV engine swap headaches (p0135)
Old May 6, 2025 | 04:27 PM
Scottieup's Avatar
Default LEV to ULEV engine swap headaches (p0135)
Hello
I swapped a ULEV 2000 into a 2001 Accord that had a LEV motor. All the connections fit and none were left over. Both have a distributor. The upstream sensor is from the ULEV but the downstream one is from the LEV tests good. Car runs great at start up but after a few min when given gas it will only go to about 2500rpm then will cut out and bounce unless you back off the gas. Fuel pressure good. PCM is original one from car so it was for LEV maybe this is problem? As stated engines both had all same connections and connectors. As stated it has a p0135 code that instantly returns on startup after clearing.
Any serious ideas appreciated.
Old May 11, 2025 | 01:59 AM
RC Perspective's Avatar
Default Re: LEV to ULEV engine swap headaches (p0135)
Originally Posted by Scottieup
Hello
Cross reference the PCMs from the respective cars. If they differ, install the ULEV PCM. Though even if they are the same PCM number, bet on the ULEV tune differing from the LEV tune. So I'd swap the PCM out anyway IMO.
Match the 02 sensors to the engine being used.
-RC
Old May 11, 2025 | 06:01 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Hello
The ULEV upstream sensor is an Air Fuel Ratio (AFR) sensor. Whereas your original motor has an oxygen (O2) sensor.
The P0135 is an O2 sensor trouble code.
Use the O2 sensor from original engine.
Kyler Yorke
Oct 2, 2020 04:32 AM
2001GSRSC
May 18, 2019 10:02 AM
Thoughtful Nate
Apr 19, 2013 11:38 AM
dracos2001
Jan 10, 2007 07:49 AM
Avante
Jul 8, 2002 12:50 PM
