F22B1 with F22A1 head. Timing belt issues
Old May 2, 2025 | 04:53 PM
grzmnky's Avatar
5 Year Member
Default F22B1 with F22A1 head. Timing belt issues
I have a f22b1 block and a f22a1 head. The block seems to be a 94-97 accord vtec bottom end with a 92-96 prelude sohc head. I tried a gates t187 timing belt for the prelude and it was too long. So I tried one for the 94-97 accord vtec and too long too. With the tensioner maxed out it’s too loose. I checked the water pumps between the engines and they are the same part numbers as well as the tensioners. Both are the same between engines. Does anyone know a belt that would work?
Old May 4, 2025 | 07:00 AM
Aradin's Avatar
Premium Member
Default Re: F22B1 with F22A1 head. Timing belt issues
All the blocks are the same deck height. Only the VTEC model cylinder heads are slightly taller and require a slightly longer belt. Since you are using a non-vtec head then a non-vtec belt for any F22A/F22B2 is correct for your application. If you're having issues with one of those then you have another problem somewhere else.
Old May 4, 2025 | 08:07 AM
grzmnky's Avatar
5 Year Member
It ended up being the bottom crank gear. It is smaller on the vtec engine. I took the gear off of the engine I got the head from and it is definitely larger
Alex72
Engine Machining & Assembly
Nov 1, 2020 12:16 AM
4doorcivic16
Apr 28, 2010 04:52 AM
yrulkn@me
Jul 2, 2007 06:09 AM
Patrickchampagne2006
Mar 12, 2007 11:54 AM
iNetForce
Jan 30, 2004 07:56 PM
