Misfire please help!!
Old Apr 28, 2025 | 01:17 PM
CMFlex's Avatar
Default Misfire please help!!
Wassup yall. Have had this civic for about 2 years now and Ive recently been having misfires.
When im steady on highway it’s fine, but if I get off throttle and get back on there’s a slight jerk. Also from a dead stop, the revs will bounce before finally getting going after some extra throttle.
Timing belt was done not too long ago maybe 20k miles or so. Spark plugs and wires also done about 5k ago.
I was thinking it could be the coil pack but my go to guy said these engines don’t have coil packs (d16 non vtec) and he suggested that it may be the distributor that’s bad.
My o2 sensor is also bad. Has been that way since I got the car.
Just looking for any suggestions on where to look first? Prior to this the car has been extremely reliable. Have driven from NYC to Toronto and back a couple times, no issues. Nowadays, it’s not being driven as much as I’ve been living over the road.
Old Apr 30, 2025 | 10:54 AM
zPandamoniumZz's Avatar
10 Year Member
Default Re: Misfire please help!!
Inside the distributor there's an ignition coil. The symptoms you've described are similar to what I had. I remedied my car by changing the main relay, which would be on the right side of your dash, behind the glovebox.
Old May 1, 2025 | 07:04 AM
Heysoos's Avatar
Loved
Community Favorite
As mentioned, the coil pack may have a problem. I’d highly recommend addressing your O2 sensor, as this helps the ECU determine the air/fuel mixture. You have a known problem, address that first, and see where it stands before throwing more parts at it.
nonamedude
17
Mar 22, 2012 06:11 PM
EvilGreenEyes
Sep 9, 2009 07:58 AM
Mrbigaznboi
May 5, 2009 01:09 PM
scrEaMO Kyle
Jan 25, 2005 07:55 AM
94gsr_vtc
Nov 4, 2004 12:55 AM
