Distributor wiring harness question
Old Apr 25, 2025 | 07:18 PM
H22AEuroR's Avatar
Default Distributor wiring harness question
So I bought a 99sh that has a euro r engine swap they went from obd2 to 1 distributor but I want to change it back to obd2 does anyone have a detailed diagram or any advice would be so incredibly helpful
Old Apr 25, 2025 | 08:23 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Distributor wiring harness question
Why do you want to change it back ?
Old Apr 25, 2025 | 09:25 PM
H22AEuroR's Avatar
Just one less thing that is confusing to me I figure it's just better to put that back regular cause having a euro swap already makes me feel dumb
Old Apr 25, 2025 | 09:31 PM
H22AEuroR's Avatar
Also was told that the td89u dizzy is the one that works and it's obd2 only having 1 plug only problem being the previous dizzy was straight wired so no female clip from the harness which is why i want to switch and need to know color matches from harness to dizzy
Old Apr 26, 2025 | 08:19 AM
theYBLEGAL's Avatar
Loved
(they are all the same on the inside, the mounting ears vary is all)
Old Apr 26, 2025 | 09:30 AM
H22AEuroR's Avatar
thank u so much
Old Apr 26, 2025 | 07:52 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Unfortunately, in the case of the H22 engine, changing from OBD-1 to OBD-2 style distributors (or the other way) isn't as simple as a conversion/adapter/jumper harness. OBD-1 style distributors have the TDC, CKP, and CYP sensors all inside the distributor housing... on the OBD-2 style distributors, only ONE of these three sensors is found inside the distributor housing and the other two are found at the crankshaft and use both the crank gear and the balance shaft drive gear to trigger these sensors. This means that changing from OBD-1 to OBD-2 style distributors on the H22 may require a distributor change, an oil pump change, a crank gear change, a balance shaft drive gear change, adding the sensor pair at the crank, and a lower timing cover change... not to mention properly connecting the appropriate wiring.
You need to know how the wiring is set up in your engine bay first before you start making this change. Posting a pic of the wiring right at the distributor as well as a pic of the wiring plug found down along the left rear edge of the engine close to the crank pulley.
The biggest difference between USDM and JDM distributors for the H22 are that USDM distributors have external coil assemblies whereas, the JDM distributors have internal coils just like Civics and Integras.
Old Apr 27, 2025 | 06:50 AM
H22AEuroR's Avatar
From all the information I gathered the td89u I have does indeed have all the sensors in it but that doesn't mean all the information is actually correct
then also as far as i understand to switch from external to internal is just putting a 30amp fuse in the plug going to the external coil which is supposed to basically reroute it back to the internal coil
RACEPAK
Aug 28, 2009 11:29 AM
cfwthb_94
Apr 21, 2009 07:29 AM
Neukin
Feb 22, 2003 10:39 AM
