Disconnect Fans Connector And Both Fans Run
Old Apr 19, 2025 | 08:28 AM
jmerritt10340's Avatar
10 Year Member
Default Disconnect Fans Connector And Both Fans Run
1998 Accord LX 2.3 l testing the fans and disconnect fan connector to jumper pins to test the fans and when I turn ignition on both fans run without the jumper. I am having an over heating problem when not moving so not sure what to think.
Old Apr 28, 2025 | 11:32 AM
10 Year Member
Default Re: Disconnect Fans Connector And Both Fans Run
I found that the fan temp sensor was bad and now the fans both kick on at 200 degrees. However, if I drive at highway speed everything is OK but when I come to stop after driving at high speed both fans run but the temperature rises to the top of the gauge jst short of boiling over. New Aisin pump and thermostat and hoses. Flushed the radiator inside and out. New fans. Any ideas?
mr.mightyone
Feb 24, 2015 08:05 PM
LMPitts
Feb 20, 2014 10:41 AM
JimRaynor90
Sep 7, 2013 02:22 PM
99HORSEPOWER
Oct 24, 2012 03:08 PM
Jdmsolutions
Nov 16, 2006 12:47 PM
