Have gas coming out of headers
Old Apr 15, 2025 | 04:44 PM
Espain33$'s Avatar
Icon5 Have gas coming out of headers
I have a 99 Honda civic si with a b18b1 engine and I’m having quite a bit of gas coming out of the headers where it connects to head quite significantly a lot why is this plz anything helps
Old Apr 15, 2025 | 10:49 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Have gas coming out of headers
Fuel injector stuck wide open in the offending cylinder ?
Old Apr 16, 2025 | 02:51 PM
Espain33$'s Avatar
Yes exactly thank you I found the injector that was stuck I replaced it
Old Apr 16, 2025 | 02:52 PM
Espain33$'s Avatar
After I replaced the injector I been driving around and even added seafoam to try to exit all that gas and done a oil change spark plugs but why am I getting a lot of blue smoke from my tail pipe.?
Old Apr 16, 2025 | 09:44 PM
JRCivic1's Avatar
10 Year Member
Community Builder
You may have washed out that cylinder... scuffing the cylinder wall. It may also be that some combustible fluids (oil and fuel) have gotten pumped into the darkest corners of your exhaust system... and they must BURN out. Since the entire exhaust system really doesn't get hot enough all over to do this effectively... this process may take a while.
Prepare for the worst... and hope for the best.
Old Apr 17, 2025 | 08:25 AM
Espain33$'s Avatar
Yeah because it’s a lot of blue smoke with the smell of gas as well and my gas doesn’t seem to last either when I replaced head gasket I had to make some modifications where the dial pins go they wouldn’t fit the hole so I made the holes bigger so it would fit you think maybe that could be reason!? Just wanted to ask and I took it last night for a hour drive on freeway and smoke seemed to get less but there is smell of fuel and fuel economy is **** so I agree with you maybe it did get to the deepest corners of my exhaust because where headers connect to the pipe underneath u can see dripping of oil mixed with gas so I’m thinking it’s what you said just needs to burn it out fingers crossed 🤞
Old Apr 17, 2025 | 08:35 AM
Espain33$'s Avatar
Also can it be a bad manifold that could be the culprit.!? And is there anything I can do as to adding a cleaner to the gas tank something to speed up the burning out process or anything you maybe suggest!?
tasiacollins
Dec 5, 2017 01:53 PM
miguey310
14
Jan 13, 2009 04:44 PM
Felliph3
Oct 10, 2006 08:50 PM
Beave0101
Jan 2, 2004 11:40 PM
